Maxxair Deluxe
If you are at all on the fence about installing a MaxxAir its really not a difficult mod. It is a bit time consuming but there is nothing technical about it. Its was a bit freaky drilling holes in my T@B but it all went fine. And its so quiet on the low speeds. Well worth it. I picked mine up from Camping world for about $250 during their Labor Day sale.
 20 T@G XL Boondock and 2019 Ford F 150 4x4
Madison, Wi
  • Photomom
    Photomom Member Posts: 2,217
    What what holes did you need to drill?
  • B0atguy
    B0atguy Member Posts: 268
    From the NuCamp factory, the OEM Fantastic fan is not installed using screws . Only butyl tape and sealant . Seems crazy to me, but it holds somehow !
    When installing a Maxxair replacement vent fan , there are 16 screw holes that must be drilled to attach it to the roof . There are some pictures showing this in an install thread I posted ......
    https://tab-rv.vanillacommunity.com/discussion/9490/2019-320s-oem-fantastic-fan-to-maxxair-installation-complete#latest
  • jrhamel
    jrhamel Member Posts: 101
    @Photomom I know its seems crazy to drill hole in your T@B but its really not a big deal and you can be sure it will never come off. There is aluminum around the fan whole that you drill into and screw the fan into.
    Madison, Wi
  • Photomom
    edited September 2019
    Wow, I should climb up there and make sure my factory installed Maxxfan was screwed down! Although it has held for 4 seasons...
