Stripped screw holes
Tartantrio
Member Posts: 8
Anyone have a good method to repair stripped screw holes in Azdel?
Poke some toothpicks and a little bit of sealant in the hole, then the screw will have something to grab onto.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL1 -
Use a slow curing epoxy along with the toothpick/sliver of wood. Do not use an adhesive that hardens to a brittle state. Avoid quick cure epoxies. West Systems G-Flex (thickened) is the ideal product for the repair.2
Thank you, I'll give it a try.0
A follow-up question on procedure: I'm guessing one should get a fair quantity of G-Flex into the screw hole(s), reassemble (e.g., tape into place whatever had been attached) and allow 24 hours or more to set. Does this sound about right?Tartantrio - How did your repair work turn out?
2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno0 -
Use a larger diameter and possibly longer screw.
Insert an appropriate size plastic electrical tie; then the screw, tighten, and cut off the tie flush. This is not for heavy or structural loads.400 - 2019
St Catharines, ON0 -
Alternately you could use stainless steel machine screws with nylock nuts on the inside wall for this.
Brad2020 400 BDL aka "Boonie"
Concord, NC1 -
The shore power socket gets lots of use and is only screwed into the foam wall. The ideal solution is to buy an extra long drill bit, drill through the wall then replace the screws with bolts and nuts. Mine hasn't moved in years.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
this is gold. It got me out of a pinch this trip. Love the forum.RCB said:Insert an appropriate size plastic electrical tie; then the screw, tighten, and cut off the tie flush. This is not for heavy or structural loads.2019 T@B 400 BDL 2017 F150 3.5L Ecoboost
Jeff & AmyNow in Manistee, MI0
