There have been many explanations of this mod. I did this this weekend so I can open my truck tailgate when hitched. I also bought a 11" hitch to also help. I now get an inch of clearance so it's good. The job requires the lower hole that the jack slides thro to be opened up. The top hole is fine. I did this with my Dremel and a small grindstone. Round and round and round the hole inside- 4 battery charges worth. Then sprayed the insides black. The three bolt pattern fits the new jack. But at the front where the hitch plate is I ground the end off the jack plate so it fits flat. You could pack with washers but didn't like the look. Sprayed ground edge with silver paint. Greased everything and bolted up. I put nuts on the bottom of the bolts after they are threaded in. Just in case.
Looks great. I have pictures if anyone needs them but there are many awesome write ups already.
I just tried to install an Ultimate Jack on my 2021 T@B 400...and have the exact same problem with the lower hole being much too small (but concentric). Just venting at this point, but why in the name of all things good, would the lower hole be smaller than the upper one? Seems like a truly stupid bit of engineering from norco.
I guess I'll try the dremel routine and see if I can get it opened up enough to make it work, but it is in such an inconvenient place to work on! Plus it's already about 1,500 degrees and 3000% humidity here in NC, so outdoor work is a bit painful.
Jeff & Amy
Thanks for the encouragement to go for it and open up the bottom hole for the jack...and also for the idea of grinding the end off the Ultimate Jack mounting plate so it fits flush on the T@B's mounting surface.
I ordered this die grinder bit from Amazon and used it in my drill, and it worked perfectly to open up the hole (really only took less than five minutes), and to grind off the end of the mounting flange that was too long (I don't currently have an angle grinder, so this was my use-what-I-got solution...but it worked great.) And by dumb luck I had the perfect metallic silver rustoleum paint to touch up the mounting plate.
https://www.amazon.com/gp/product/B085T1ZZCG/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
So far I like it a lot. The ability to drop or raise the bulk of the jack without cranking endlessly seems like a big advantage. I also like the fact that if I want, I can remove the plastic keeper on the base collar and remove the entire jack very easily. I want to use it some more to decide if I want to just remove that plastic keeper or not...but I like having that option.
It also seems very sturdy and well built, and came with a jack foot plate that I wanted to have, so I consider that a small bonus!
I had initially tried installing it using washers to raise the mounting plate to gain clearance over the welded plate on the coupler, but trimming the Ultimate Jack's mounting plate for a flush fit is definitely the better solution - thanks again for that nugget of user wisdom!!
2024 NuCamp T@B 400 BD, Charcoal / White
Advice?
