RV antifreeze?
What brand of RV antifreeze do you use?  I am going to do the antifreeze method of winterizing.  I have read some negative reviews of the Walmart brand of the pink stuff "Super Tech RV & Marine"--anyone used this brand?  Would like to find a propylene glycol (no alcohol) based brand, or are all RV antifreeze the propylene glycol.  Camco brand, of course, appears to be the most expensive.  Are they all the same?
2018 Tab 400
    ScottG Administrator Posts: 5,696
    edited September 2019
    What did the negative reviews say? Does it freeze when it's not supposed to?
    I just grab whatever pink stuff is handy when I'm thinking of it and everything seems just fine come spring. But I like livin' dangerously!  ;-)
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    Pink stuff is NOT all the same. You can have alcohol based, PROPYLENE GLYCOL or a mixture. Professional RV places recommend pure PROPYLENE GLYCOL ONLY as alcohol tends to dry plastics and rubber out and also can leave bad taste even after flushing.
    Of course the "good" stuff is more expensive as most things in life!
    As far as brands, I need to look at what I got from my local RV place. I had to ask for it, the stuff out front on the shelf was a blend! I have heard that Rain-x makes it ,but be sure it isn't a washer fluid!!
    Most brands are rated by burst temp, NOT freezing temp which is typically much warmer. The burst on most is -50F, BUT some brands also sell burst of -100F, of course for more money.
    https://recvehicle.com/winterization-and-rv-antifreeze/
  • VictoriaP
    VictoriaP Member Posts: 1,496
    I went with South/Win from Home Depot. Propolyne glycol based and easiest for me to quickly get my hands on.
  • lkc001
    lkc001 Member Posts: 881
    @ScottG several comments said they still had something crack over winter.  That is concerning.
    2018 Tab 400
  • lkc001
    @N7SHG_Ham would like to know the name of the antifreeze you use.  Thanks for the article.
    2018 Tab 400
  • lkc001
    @VictoriaP Thanks!
    2018 Tab 400
  • N7SHG_Ham
    I think the brand I used is Winter Safe, BUT I will double check that later today, my friend just sent me a photo of a jug he bought at same place on my recommendation, I will attach it, BUT it doesn't clearly show the actual
    brand.
  • lkc001
    @N7SHG_Ham Thanks!
    2018 Tab 400
