Hello Folks,
I have read as much as possible on towing a NuCamp T@B 400 and what the best TV is etc. However, I am not completely confident in my understanding of all the comments posted.
We currently have a 2019 T@B 320 Boondock Edge and tow with a 2016 Honda Pilot AWD. The Pilot puts out 280 HP and 262 ft/lbs torque. We have not noticed any major problems towing the 320 Boondock.
We are considering upgrading to a 2020 T@B 400 as the bathroom in the 320 is rather tiny. However, will the Honda really be up to the job?
As I mentioned above, I have read the really good information and I fully understand that its not just getting the trailer down the road, its also about WD and the overall enjoyment of the trip. We tend to do very long trips and I often drive for a full day. A friend used to tow his Airstream with a Ford Bronco and always complained that he had a very rough day out on the road. I do not want to be in the same position.
Would a WD hitch be advisable and what are the impediments to installing one? I understand the crushing of the frame. Would it be a better solution to drill holes in the frame to mount the L brackets if this is even possible?
Anyone have an opinion of drilling holes in the frame and what does the manufacturer say?
I can see that the 400 has a fairly high tongue weight as the wheels are set back far under the trailer.
I know this is an old subject and has been covered, however, I am still not totally confident in my understanding of the Pilot and towing a 400.
Thanks,
Keith Stamper
2019 T@B 320 Boondock Edge, 2016 Honda Pilot AWD
0 ·
Unless your Pilot has a full frame is not unibody, I would not recommend a WDH.
…… Just my two cents:)
Hamburg, NY
The unibody vs body on frame debate is a holdover from the debate about whether you should ever tow with a vehicle other than a truck. Today, there are many very capable SUVs that can tow modest loads without issue relegating the debate to one of preference, not requirement.
I will probably test-tow the 400 before we decide. Also it will of course depend on the deal they offer me. The only issue I have with the 320 is the bathroom is small and I did not realize at the time of purchase that it would be a problem.
The Honda is an 8 passenger vehicle and has three rows of seats. When we tow our 320 it’s just my wife and I plus two very small dogs. We do not load up the back of the TV
Thanks again
Keith
