Help with the gray/black water tank valves
Most of the time, you still have to get down there to hook up your dump hose. But, sometimes this might help for muddy situations.  Here is a pic from loveyourrv of a pvc pipe hook for the drain valve.
Simple le to make.  They also mentioned a little 100% silicon spray on the valve rod.  That seemed reasonable...
2016 NuCamp 320 T@B Max S
T@bbey  Road
Appleton,  WI
