Two of the four bolts holding my the tub on one side of the frame of my 2016 Tab Outback Max S came loose or were never installed. The other two bolts were fine and appear to have lock nuts. We haven't taken the trailer more than a few thousand miles on fewer than half-a-dozen trips, so I'm wondering whether the nuts were ever installed on those two bolts. I wouldn't have known that I had a problem, but vacuumed up the bolts and washers when cleaning up after installing expanded aluminum to close the opening behind the tub.
0 ·
2016 Jeep Cherokee & 2017 T@B Outback
Did you have to go "Vacuum Bag Fishing" for the bolts and washers?? hehe.
Odessa, Fl.
When the Boondock tub was off I upgraded to longer 5/16" SS bolts with lock washers and nuts on bottom of tub before mounting to frame. Then adding washers and self-locking nuts on bottom of frame flange. Now removing the tub is a one man job. The bolt upgrade was due to installing 2 AGM Group 31 batteries in Tub. The propane bracket was removed adjusted and rewelded to make room for the batteries.
2024 T@g 5-wide Black Canyon
