Friedrich air conditioner CP06
JP2558
Member Posts: 248
Does anyone know if this will run on 15 amp service? The manual doesn't state it directly but it does say the circuit rating for the time delay fuse is 15 amps and 125 volts.
Thanks, Jerry
You will be OK. Use an extension cord with sufficient gauge to minimize voltage drop. The AC typically draws 5-7 amps.T@B: 2018 320-CS Max
TV: 2017 Toyota Highlander1 -
Thanks for the input!
Thanks, Jerry
2019 Honda Pilot AWD and 2018 T@B 320-CS hanging out on the left edge of Lake Erie.0
- 417 Service/Maintenance & Recall Notices
