Hail damage to solar panels on a 2020 T@B 320
Jeansor
Member Posts: 28
My husband and I are going to look at a trailer that has received some hail damage. We've been told it's minor, small mostly pea-sized dings to the roof. They said that the solar panels were damaged also but that they still work. We're going to look at it in person but I'm just wondering if anyone knows how hail damage affects the performance of the panels.
2013 Nissan Frontier
2020 T@B 320 S Boondock Edge: Sm@lls
I doubt pea sized hail could dmage them. But in a glass panel it would fracture the solar cells flexible panels are probably the same
Hook to the victron controller in the trailer via bluetooth and the victron app via smartphone. The victron code is 0000 or 00000
With the trailer unplugged from AC power and the battery switch on.......turn the refrigerator on dc power and give it a couple of minutes.
Open up the victron app and see what the current delivery is to the battery.....IMO anything over say 14 volts and 5 amps you are doing okay.
The solar panels are not mounted for optimal performance and I have been disappointed by the performance of mine.2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods -
They might still "work" but they might be damaged in such a way that they are "working" at a reduced capacity.I have a flexible panel (not installed on the camper) that has lost half its capacity because one or two of the elements have failed for whatever reason.So, unless they can prove that the panel is working to specifications, don't assume it is ok.If you know how to use a multimeter, bring it.Edit: Cbusguy is correct. The Victron app will tell you how much the panel(s) are putting out. Just make sure the trailer is in as good a sun as you can get.
Towed by 2014 Touareg TDi -
If the dealer doesn't have a battery in the trailer. Don't use the fridge on dc as it will never start. Try using the roof vent instead2009 GMC Canyon, 3.7 liter
If tif you need to replace them get 2 of these. Easy install.
https://www.windynation.com/Monocrystalline-Solar-Panels/WindyNation-Inc/WindyNation-100-Watt-12V-Flexible-Solar-Panel-with-Monocrystalline-Solar-Cells/-/2855?p=c3E9RmxleGlibGUrcGFuZWw=
aka BirdieJane towed by Quinn -
Thanks for your replies. We're new to all of this and trying to figure out as much as we can.
- 917 Introductions
- 73 Teardrop Groups & Links
