Can you have 2 batteries in the tub and the tire on the front jack
lino
lino Member Posts: 246
edited September 2019 in Modifications & Upgrades
Title kinda of days it all
Has anyone made this modification in this way? Wondering if I’m going to need to move my spare tire to the back of the T@B
I have a 2017 Q
Going to the factory in 2 weeks and am very excited
  • jrhamel
    jrhamel Member Posts: 101
    I think that depends on the tongue weight of your TV
     20 T@G XL Boondock and 2019 Ford F 150 4x4
    Madison, Wi
  • sranderle
    sranderle Member Posts: 78
    Yes, I had two golf cart batteries in the tub of our 2016 Q, and our spare is mounted on the front jack.  The batteries are a snug fit, but it does work.
    I decided to upgrade from the tub to a truck box this year.
    Steve & Sherry
    2016 T@b Q
    Lakeville, MN
  • Michigan_Mike
    Have you spoken to the repair shop?  I’m certain it’s possible with a front tub and since they place the tires on the front of the 400’s it should be doable with your trailer.  In the past I have seen others use a modified vehicle tire storage assembly mounted to the front of trailers, allowing people to lower the tire down via a cable.  Anything can be done as long as tongue weight requirements are adhered to and available clearances are there.
  • GatorEgg
    GatorEgg Member Posts: 482
    Yes, do a search on this forum.  There’s many folks have done it.
    Odessa, Fl.
  • lino
    Thanks everyone
    Have been working directly with factory and Austin has been great
    Just looking for more feedback here and got it
  • lino
    edited October 2019
    Here is a picture of our new tub and batteries.
    Austin from NuCamp recommended not using the plastic battery box I got from Amazon to use in the tub. I used two 6 volt Interstate Golf Cart Batteries.
    Thanks to everyone that helping in both threads I started about this mod
  • GatorEgg
    The Teardrop  Shop also markets a mount for this.
    Odessa, Fl.
  • lkc001
    lkc001 Member Posts: 877
    @lino. Are you going to have a cover on the batteries to keep water out & protect from something falling on the connections & posts?
    2018 Tab 400
  • lino
    edited October 2019
    Ick001-So far no cover
    I asked about this and Austin felt it was not needed
    I don’t plan on storing anything else in the tub since we don’t have a bathroom  or use hoses
    Is there a cover that would fit? I could not find just a cover
  • Dalehelman
    edited October 2019
    We have 2 batteries plus a Honda 2000 generator and still under 300lbs tongue weight. Tows beautifully.
    1. Hash  T@B Fun
  • lino
    Thanks, nice set up
  • lino
    In the picture I have the outback diamond plate tub open just to show off the set up
    Hard to see it in the picture
  • lino
    I used interstate 6GC2 golf cart batteries
    I switched to the outback diamond plate tub which has two handles to thread the tie down strap through
    The NuCamp repair shop installed the batteries, switched the tubs and did the wiring.  Batteries sit directly on the bottom of the tub with no other hardware.  Seems solid and does not move
  • ChanW
    ChanW Member Posts: 3,165
    edited October 2019
    @Dalehelman, I'm interested in your load balancing...
    I finally got around to actually weighing our Tab tongue, rather than relying on my back to estimate it (ouch!)...
    It turned out to weigh in at just under 300# dry weight, more than I like if we're going to put all those beers in the fridge (Ok, it's probably going to be ice, milk for coffee, and wine...), and any other sundry items forward of the axle.
    This is with the standard plastic tub, twin 6V GC batteries, a smaller 10# propane cylinder, the new plywood floor in the tub, and the spare tire on the tongue.
    It surprised me that it went up so much with the addition of the second battery and plywood floor. I re-moved the spare tire to go under the bed (behind the axle) and that brought the tongue weight down enough to make me happy, but we still need to be careful loading the Tab and the back of the truck.
  • lino
    Have not weighed it but it drove great and did not notice any problems.
    To compensate I did pull out most of the gear from the trailer that I used to store and two tubs. I can easily fit them in the car
  • lino
    If I notice issues will put the tire in back to original spot
  • Dalehelman
    As long as I am under my vehicles tongue weight hitch tongue weight and trailer tongue weight limits. I find the more weight on the tongue the better the trailer tows. I make know adjustments even with a full fridge and holding tanks.
    1. Hash  T@B Fun
  • lino
    I agree with you for sure
    For now will keep trailer light and can add weight if needed
    We mostly just keep a small amount of clothes and bedding inside. The rest in the tv
