Add vent to reduce 2-way fridge energy use?
ckjs
Member Posts: 137
There are many reports of the Norcold 740 fridge in a CS using 500-something watt-hours per day. The CS kitchen area is well sealed off from the outside, so all the heat pumped out of the refrigerator is trapped underneath the clamshell — which can get really hot from the sun on its exterior. I think the poor fridge is spinning its wheels heating up the kitchen. How about an exhaust vent to reduce its energy consumption?
I’m thinking of adding an opening and a small fan to at least circulate the kitchen airspace with the interior of the cabin. The outside sidewall is right there, but cutting a hole in the side is a scary mod.
Has anyone added ventilation so that the waste heat of a two-way fridge has somewhere to go?
Someone else had issues with the heat from the CS Norcold. The TaGs have a chest-style Norcold installed and there is a vent in the floor under the frig. We have a factory installed ARB in our CSS galley and we had them place the same vent in our galley floor. So far, no problems.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
@Bill_in_Tulsa has a Silver Shadow teardrop with the galley in the rear like your CS/CSS. He put an extra vent on the outside wall to help ventilate the heat. He covered the hole with a “cowbell”. Hopefully he will chime in when he has time during his travels.Verna, Columbus, IN
I added cold air intakes and ducted the hot air out. So far it is working well.
https://tabforum.nucamprv.com/#/discussion/9920/mod-for-better-fridge-cooling-in-clamshell-t-bs
T@B: 2018 320-CS Max
TV: 2017 Toyota Highlander -
ckjs - Did you ever end up doing the Mod to your TAB 400?
Trailer - 2018 Tab 400 with Solar
TV - 2014 Toyota Tacoma Double Cab with bed rack/truck tent
Adds - Jackit bike rack with tongue rectangular tool box -
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
