Winter Cover suggestion for 2011 T@B
Luitjens
Member Posts: 2
We have a 2011 T@B and are looking for suggestions on covers and where to purchase. See lots of options for RPods and curious if anyone has used one that is "close enough" on the sizing. Thanks
Fits and works great:
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut -
@Luitjens, I agree with @webers3. However, after I purchased the Classic Accessories PolyPro 3 cover through Amazon, I contacted the manufacturer and learned that for a little bit more money, their PermaPro cover provides better protection. Regardless, my trailer is stored in a covered facility, so the PolyPro 3 works very well for my purposes. I think it just has thinner material. If you live in a colder part of the country, you may prefer the PermaPro, but it looks like the main difference is that the PermaPro has the added "tear-resistant" feature. Possibly a little heavier too. Either way, it is a very good cover with a well thought out design.
[SIDE NOTE: I own a 2019 T@B 320S Boondock Lite. The PolyPro 3 and PermaPro covers with a 10'-12' fit does not also cover the Boontock aluminum tub (although it should not be a problem with your trailer). Because of that, if I need to replace the cover in the future, I will probably switch to the Classic Accessories 16' R-pod cover.......another T@B owner previously posted that it will cover the aluminum tub.]
https://www.amazon.com/Classic-Accessories-80-399-161001-RT-10-12-Trailer/dp/B071WY3G5Y/ref=sr_1_16?crid=1UCQF0SL7J0BL&keywords=permapro+cover&qid=1570660668&s=automotive&sprefix=perma+pro%2Cautomotive%2C200&sr=1-16
Here's the info that Classic Accessories sent to me to compare the two covers:PermaPRO Fabric
100% Woven Polyester Ripstop
· Tear-resistant
· Water-repellent
· Bird dropping protection
· Dirt, dust and scratch protection
· UV protection
· Snow protection
PolyPRO 3 (includes the following features):
PolyPRO 3 Fabric (Top of the cover)
PolyPRO 1 Fabric (Sides of the cover)
3-Ply Non-Woven Polypropylene
1-Ply Non-Woven Polypropylene
· Water-repellent
· UV protection
· Snow protection
· Breathable
· Water-repellent
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
I use the Classic Accessories PermaPro RV as well. Works great. I keep my T@B covered when its out from the garage and seems to be holding up good. Especially in this South Texas heat / sun.
- 920 Introductions
- 74 Teardrop Groups & Links
