I've done troubleshooting but no fix yet. We have about 12 hours playing new DVD movies in this machine and it's been perfect. Last week when loading the same DVDs previously viewed the Jensen menu screen says LOADING, and that's as far as it'll go. Music CDs, radio, tv, all work fine. Movies suddenly stopped playing. I've cleaned the machine with canned air spray, disconnected power over night, hit the reset button a dozen times.
I contacted Creed at NuCamp and got a timely response but he referred me to ASA Electronics (JENSEN). I contacted them already, I'm waiting for another reply back from them on warranty timeline.
Has anyone had this issue and did it get resolved, other than by a warranty claim?
Thank you,
TOULA
2019 T@B 400 -- 2017 Toyota Tundra
South Louisiana
1 ·
https://www.asaelectronics.com//customer-service
Harpers Ferry, WV
TOULA
South Louisiana
ASA Electric was great to work with.
Harpers Ferry, WV
Toula
South Louisiana
It is a DVD Player . . . . . . does not like Blu-Ray
And of course after a long day I discovered the one disc picked up off the house table when rushing out was the wrong darn format. Oh well, did have some OTA MeTV . . . . '70's here I come.
South Louisiana
Chili, NY
Toula
South Louisiana
Basic reset is to:
1. Power on and place on AM setting
2. Press and hold SETTINGS button 2 -3 sec until a system menu appears, then tap the SETTINGS button to scroll thru the system menu until you see RESET on the display and stop.
3. Press the VOL wheel to enter the reset command. Radio will then default to FM mode if you did it right.
This works for some issues described above.
Second reset is the ASA Electronics "in house" reset.
1. Turn radio on and tune to an FM station so you can hear audio output
2. Take a paper clip and press and release the reset in the small hole below the VOL wheel. Unit will power off and then return to FM when you release
3. Press and hold the small EJECT button for a count of 7 seconds and release.
This procedure helps to reset the head position on the CD/DVD reader, and can be repeated as the unit "learns" with each iteration. He had me do it 5 times, in sequence, and then try an audio CD again. The unit sounded as though it was going to read the CD, but still failed. This does however work for many loading/reading issues.
For my problem ASA electronics tech support said that I could contact my NuCamp dealer (mine is 4 hours away) for a replacement, or send my information via email directly to them and they would send a return authorization#, evaluate the unit and ship a replacement. He was very understanding and not picky about the unit being a little over a year old.
In short, ASA electronics was VERY helpful and easy to reach and talk with. Quite a relief and a pleasant surprise so if your unit is giving problems they may be able to help even if you are a bit out of warranty.
