On the rear window of my 2019 Tab400 I have several lock latches that are very hard to close/lock. I noticed that the strike plate mounted to the window frame is not aligned with the lock handle (see photo and red circles, this photo window is unlocked). I can see they are designed to mate and engage each other. I imagine moving the strike plate a little will align them but I am concerned the new holes for the two mounting screws in the new locations will be so close to the previous location that they will strip out. Anyone else experience that and have a repair that worked for them?
If you do need to drill new holes for the strike plate, I'd guess that taking off the plate, filling the hole with a strong construction adhesive, then carefully drilling new holes after the adhesive sets would work fine.
Southern California
Full-timer since 2019
Is the latch on the other side misaligned in the same manner? If so, @N7SHG_Ham has nailed it. Open all the latches, raise the window slightly and slide it ever such a little bit sideways. You may have to adjust the side latches a little but that is just a matter of loosening the hold down screws on the frame.
Southern California
Take the screws out of the plate, slide it over to align and see if there's room to drill new holes. If not, you might be able to install a thin metal strip under the rubber and then drill your holes. Otherwise, Michigan Mike's suggestion to dremel out a "sideways" slot might be the way to go. Good luck.
Springfield, MO
Southern California
Springfield, MO
