Alde Manuals and Resources
ScottG
Administrator Posts: 5,701
Manuals and other resources for the Alde Compact 3010 and 3020 boilers.
Typical Alde Fuse and Circuit Breaker Locations
Description: Fuse and circuit breaker locations for the Alde 3010 boiler.
Created by: Michigan_Mike
Posted by: Michigan_Mike
ALDE Fuse Location on ALDE unit
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
Digital Control Panel Tutorial
Description: Video tutorial for the use of the the 614 digital control panel.
Created by: N/A
Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
https://youtu.be/Jl8xNCs7xww?t=14
Alde 3010 Operating Manual
Description: Operating and installation manual for the US and Canadian Alde Compact 3010 boiler. Includes operation instructions for both the 614 (digital) and 314 (analog) control panels. Note: beginning in December 2017, T@Bs are equipped with the newer Alde Compact 3020 boiler. The 3020 operating manual is available below.
Created by: Alde Corp
ALDE High Altitude Regulator Installation
Description: Detailed Instructions for the installation of the Alde high altitude regulator. Installation of the high altitude regulator on Compact 3010 models may mitigate excessive boiler noise common when operating the Alde at higher altitudes.
Created by: ColoradoJon
Posted by: ColoradoJon
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ2 -
Alde 3010 Service Manual (UK version)
Description: Service manual for the Alde Compact 3010 boiler. Note that this is the UK version of the service manual. While the general configuration of the boiler should be the same, some technical specifications differ from Aldes designed for use in North America.
Posted by: ChanW
Alde 3020 Operating Manual
Description: Operating manual for the US and Canadian Alde Compact 3020 boiler. Beginning in December 2017, T@Bs are equipped with the newer Alde Compact 3020 boiler. Upgraded from the Compact 3010 used in earlier T@Bs, the 3020 features a high altitude setting and has only one glass fuse protecting the 12V power supply. Note: Older T@Bs are equipped with the Alde Compact 3010 boiler. The 3010 operating manual is available above.Created by: Alde Corp
Posted by: MuttonChops
----------2015 T@B Max S (320)
https://www.youtube.com/user/aldeheating/featured
Alde YouTube Channel
Description: Short instructional videos for operating and troubleshooting Alde boilers and components.Created by: Alde Corp
Posted by: N7SHG_Ham
Alde Glycol Brand Change
Description: Alde glycol for TaBs manufactured on or after 1/4/21 is now RhoGuard brand - RG-RTU-50 (RhoGuard Ready to Use 50/50 Mix) made by Rhomar Water.Listed purchase locations and product data and safety sheets.Created by: Rhomar Water
Posted by: Sharon_is_Sam
https://www.rhomarwater.com/index.html
https://www.rhomarwater.com/Where_to_Buy.htmlSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0 -
DIY Alde Glycol Exchange
Description: Comprehensive instructions for changing the Alde glycol using an inexpensive manual transfer pump and simple homemade adapters. Access is via the top of the Alde expansion tank and requires no disassembly or modification.
(See the full forum discussion of this topic here.)
Created by: ScottG
Posted by: ScottG
------------------2015 T@B Max S (320)
2015 Nissan Frontier SV V6 4x44 -
Alde / Truma Contact
Description: How to contact Alde (now part of the Truma Corporation)
Provided by: KAR
Telephone: (877) 860 9814Alde E-mail: service@alde.usTruma E-mail: service@trumacorp.comSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0 -
Alde Control Panel
Description: Quick guide to use of the Alde Control Panel
Created by: Alde
Posted by: carpense
