Done Deal
Hello All - picked up my new tab yesterday in Columbus, OH and got it home in one piece. I have a question about the mounted flexible solar panel. I asked the dealer where the charge controller was for the panel and he said there wasn't one, that it is just wired right into the battery. He suggested using a Victrom app. This doesn't sound right to me. I know solar panels have to have a controller. Anyone using a similar setup want to comment? Thanks, Greg
  • 4ncar
    4ncar Member Posts: 1,072
    I haven’t purchased as yet, but have a cursory knowledge of solar. Yes, you do WANT a charge controller if for the sole purpose of not over charging your battery(íes). Without one you could destroy your battery(íes) in the least or they could explode at the most. So technically you don’t need one, but not having one would be inadvisable. That said...in purchasing a victron controller along with the Bluetooth dongle, you will have the ability to monitor your state of charge.  I’ll be shortly behind you...
  • RayJim
    RayJim Member Posts: 148
    edited November 2019
    Mines was under the seat, had to unscrew the seat to get access. The solar panels are connect to the battery but there is a charge controller in between. The app is to monitor the controller remotely so you dont need to access directly
    2021 T@B Boondock 400. 2021 Toyota SR5 V6
  • ChanW
    ChanW Member Posts: 3,171
    Is it a new Tab? What model?
    I can't believe it would be sold without a charge controller.
    Agree with what @4ncar said, it would quickly fry your battery.
    Sounds like the dealer was oblivious.
    The Victron app will allow your phone to connect to a (Bluetooth enabled) Victron controller, if it's what you have.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
    Most likely, it is just another person who is badly informed about how solar works.  Too bad it happens to be a dealer, but.....
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    It has a controller almost 100% certain. AFAIK NuCamp uses across all products a Victron controller, it is blue in color and location will depend on model. There is a Bluetooth app that shows the data you need, no real need to access the controller itself.
  • gregtipton19_
    gregtipton19_ Member Posts: 25
    Thanks for the responses, very helpful. After further investigation, I do believe there is a controller located under the bed. I downloaded the Victron app to my phone then went to the camper and it was recognized so I think there is a controller to pair with. I'll check for sure tomorrow. But, yes, my dealer was oblivious.
    Glad you found your controller. Unregulated solar panels can put out around 18V in full sun--more than enough to fry your new batteries as others have noted.
