How-to video winterizing T@B 400...
MandyLea
Member Posts: 52
Hi everyone! Some of you may remember my video from 2 years ago when I winterized my T@G with vodka... well, it worked so well that we decided to do it to Little Bear, the T@B 400. But, whether you want to use vodka or antifreeze, this video walks you through the steps. In the video description you will also find a link to the blog where we have typed it out step by step. Enjoy!
https://youtu.be/0H22gcmussw
Cheers!
Mandy
https://youtu.be/0H22gcmusswCheers!
Mandy
2018 Black T@B Outback | 2016 Jeep Cherokee Trailhawk
Love & Light!
Love & Light!
2
What a great idea, then you can have a de-winterizing party pouring drinks out of the faucets, wahoo!!
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut1 -
Many of us try to avoid RV antifreeze with alcohol as an ingredient. I realize vodka is made to drink and isn't the same alcohol as in antifreeze, BUT wouldn't it have the same negative effect on rubber and plastic in the water system.2019 T@B 400 Boondock Lite0
@N7SHG_Ham if I remember correctly about three years ago Mandy Lea was caught in a freak snowstorm and freezing temps far from services. The only item she had that could protect her lines was vodka. It worked in a pinch and yes, many have since pointed out that it’s not ideal because of the alcohol content. It gave many of us a good laugh at the time and showed ingenuity when in a bind. I suspect she prefers hers from a bottle vs faucet.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
Especially since they used some cheap vodka that sounds like it is barely drinkable. I guess I don't understand the continuing use of vodka when they are better antifreeze solutions? It isn't as effective, it harms rubber and plastic and it costs more.
2019 T@B 400 Boondock Lite1 -
Didn't the video say it helps you skip the step of sanitizing in the spring?2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
