Brake wire thingy
Tweedrvr
Tweedrvr Member Posts: 122
I have this wire with a loop at one end that fits over the ball before you lower the hitch and lock it in place.  It’s like an emergency brake or something.  We my problem is that the OTHER end which has a plastic piece on it has dislodged itself from wherever it was and I have no idea where that location is on the trailer.  Does anyone know what I’m referring to?  If so, could you tell me where or better yet post a picture.  I’m hoping to sell my beauty, but I obviously need to fix this.  Much appreciated.  Thank you.
’15 T@B CS-S Max. Towed by a ‘19 Subaru Outback
    Look on the inside of the frame on the passenger side.  You should find the break away brake relay that is housed in a thin, plastic box.  Reinsert the end into the box.  You should be aware that removing that end engages the electric brakes and it can consume your battery.  Also, the other end should be attached on the hitch, not on the ball.
  • Tweedrvr
    Thank you. That helps a lot.
  • GumboAndBoo2
    GumboAndBoo2 Member Posts: 17
    And remember that the length of the breakaway cable should be less than the length of the safety chains.  If the chains are longer, the breakaway cable will never engage the emergency break.
    Jack + Grace + Gumbo (the dog) + Bubo (the other dog) + Alice the T@binator (2018 320 S)
    I think there was a discussion about the length of the break away brake cable in relation to the chains.  No real consensus.
  • Tweedrvr
    Thank you. Think I’ve got it covered.
  • LBHM
    LBHM Member Posts: 12
    is there a best practice for attaching break away brake cable to hitch?
    It is ideally attached directly to the TV, but most folks probably attach it to the hitch.  Some hitches provide a cut out for attaching the cable.
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    And by attaching to hitch, that should mean the receiver structure that is bolted to your TV frame and NOT the ball mount!
    Agree!
  • TabberJohn
    TabberJohn Member Posts: 588
    I used this advice as a guide:
    https://youtu.be/eubR3ssLiOM
    Should I ever need to replace the cable I'd switch to this:
    https://youtu.be/YHQf16s2NEE
  • LBHM
    thanks for the guidance...videos especially really helped!...cheers
  • MiquelCamo
    MiquelCamo Member Posts: 91
    I have the Fastway Zip cable. After watching the first video I need to ensure it's extended length is shorter than the chains. Anybody checked this out?
    Mike and Lisa Campbell
    Springfield, MO
  • Dalehelman
    1. Hash  T@B Fun
  • Tampakayaker
    My wire isn't long enough to get to the receiver bracket, it barely makes it to the ball. Guess I should look into extending it a little bit.
    Tampa FL
  • N7SHG_Ham
    @Tampakayaker yes! If the ball mount was to come out (and it has happened due to forgetting to put the pin in) you would have no emergency brake engagement. It is much less likely that the entire hitch assembly bolted to the TV is going to leave the TV.
  • Tampakayaker
    N7SHG_Ham lo and behold, I looked under the hitch platform and the previous owner had tied a loop in the wire to shorten it.  I undid the loop, put a hook on the end and attached it to my receiver mount next to the safety chains.  I had to get two of those D-Ring shackles from Harbor Freight to attach to the receiver holes so the safety chain hooks latch would close, because the latch wouldn't close when I put them on the receiver hole.
    Tampa FL
  • Marceline
    Marceline Member Posts: 1,773
    You probably figured this out, but those shackles need to be able to as strong as the chain or stronger. If the shackles are a "weak link" the safety chain won't do it's job.
  • Tampakayaker
    @Marceline, they are.
    Tampa FL
