Is there a drain plug on the Alde?
Hi, I just winterized my new 400 for the first time and it just occurred to me that I only did the bypass switch and flipped up the two yellow pressure relief valves before putting in the antifreeze.  Is there a drain plug on the alde hot water heater or the little red alde beside the main big alde? I forgot what that is called now!
Thanks!
    The only water drain for the Alde are the yellow pressure relief valves that you use to drain the water before bypassing the Alde. There was a video just posted regarding winterizing the 400z
  • [Deleted User]
    [Deleted User] Posts: 831
    edited November 2019
    Great! I'm all set then!! I will look for that video too.
