Is there a drain plug on the Alde?
[Deleted User]
Hi, I just winterized my new 400 for the first time and it just occurred to me that I only did the bypass switch and flipped up the two yellow pressure relief valves before putting in the antifreeze. Is there a drain plug on the alde hot water heater or the little red alde beside the main big alde? I forgot what that is called now!
Thanks!
Thanks!
The only water drain for the Alde are the yellow pressure relief valves that you use to drain the water before bypassing the Alde. There was a video just posted regarding winterizing the 400zSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Great! I'm all set then!! I will look for that video too.0
