Brake wire thingy
Tweedrvr
Member Posts: 122
I have this wire with a loop at one end that fits over the ball before you lower the hitch and lock it in place. It’s like an emergency brake or something. We my problem is that the OTHER end which has a plastic piece on it has dislodged itself from wherever it was and I have no idea where that location is on the trailer. Does anyone know what I’m referring to? If so, could you tell me where or better yet post a picture. I’m hoping to sell my beauty, but I obviously need to fix this. Much appreciated. Thank you.
’15 T@B CS-S Max. Towed by a ‘19 Subaru Outback
Look on the inside of the frame on the passenger side. You should find the break away brake relay that is housed in a thin, plastic box. Reinsert the end into the box. You should be aware that removing that end engages the electric brakes and it can consume your battery. Also, the other end should be attached on the hitch, not on the ball.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Thank you. That helps a lot.0
And remember that the length of the breakaway cable should be less than the length of the safety chains. If the chains are longer, the breakaway cable will never engage the emergency break.Jack + Grace + Gumbo (the dog) + Bubo (the other dog) + Alice the T@binator (2018 320 S)0
I think there was a discussion about the length of the break away brake cable in relation to the chains. No real consensus.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Thank you. Think I’ve got it covered.0
is there a best practice for attaching break away brake cable to hitch?0
It is ideally attached directly to the TV, but most folks probably attach it to the hitch. Some hitches provide a cut out for attaching the cable.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
And by attaching to hitch, that should mean the receiver structure that is bolted to your TV frame and NOT the ball mount!2019 T@B 400 Boondock Lite0
Agree!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I used this advice as a guide:
https://youtu.be/eubR3ssLiOM
Should I ever need to replace the cable I'd switch to this:
https://youtu.be/YHQf16s2NEE
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)1 -
thanks for the guidance...videos especially really helped!...cheers0
I have the Fastway Zip cable. After watching the first video I need to ensure it's extended length is shorter than the chains. Anybody checked this out?Mike and Lisa Campbell
Springfield, MO
2016 T@B Max S - Sold March 20200 -
- Hash T@B Fun
My wire isn't long enough to get to the receiver bracket, it barely makes it to the ball. Guess I should look into extending it a little bit.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
@Tampakayaker yes! If the ball mount was to come out (and it has happened due to forgetting to put the pin in) you would have no emergency brake engagement. It is much less likely that the entire hitch assembly bolted to the TV is going to leave the TV.2019 T@B 400 Boondock Lite1
N7SHG_Ham lo and behold, I looked under the hitch platform and the previous owner had tied a loop in the wire to shorten it. I undid the loop, put a hook on the end and attached it to my receiver mount next to the safety chains. I had to get two of those D-Ring shackles from Harbor Freight to attach to the receiver holes so the safety chain hooks latch would close, because the latch wouldn't close when I put them on the receiver hole.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL1 -
You probably figured this out, but those shackles need to be able to as strong as the chain or stronger. If the shackles are a "weak link" the safety chain won't do it's job.Tampakayaker said:I had to get two of those D-Ring shackles from Harbor Freight to attach to the receiver holes so the safety chain hooks latch would close, because the latch wouldn't close when I put them on the receiver hole.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
