Winter Camping Tips
13»
    edited November 2019
    For the 320, crack the front window and maybe the fan vent.  Just be aware that any draft across the Alde display will cause it to run much more frequently leading to a too hot cabin.
  • Verna
    Verna Member Posts: 6,876
    Open a window to the locked/open position (it gives you about 1/4” of window opening) and open the roof vent about 1/4”. This provides sufficient circulation of air to control the condensation from the occupants’ breathing. I’ve never had condensation using this method.
  • NomadPilgrim
    NomadPilgrim Member Posts: 111
    I also have a shower stall size rod above the toilet, for wet jackets and wet boots go on the shower floor. I took off the glass shower door and replaced it with a tension rod and shower curtain, that gives me another place to hang damp items. I use the jell powder in the toilet with trash bag liners to use the loo without running water.
    2016 T@B Maxx CS-S  following a 2008 4Runner Ltd
    Be brave. Take risks. Nothing can substitute experience.-
    Paulo Coelho
  • Tundra57
    Tundra57 Member Posts: 640
    @NomadPilgrim tell me more about the gel powder and trash bag liners in the toilet.
  • T_BDancing
    T_BDancing Member Posts: 85
    The Jensen tv generates heat and affect the Alde thermostat's temperature. The Alde thermostat says 73-79°F but a thermometer I have by the sink says between 63-68°F(depending the time of the day with sun or not). A tricky situation.
    Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L
    2019 Tab 320 S Boondock Edge and get me out of NYC!!!
    Oh, that’s a new one!
  • ChanW
    ChanW Member Posts: 3,171
    I think we found that cracking the vent and cracking a window pretty much prevented the condensation, even at 5 below.
    The walls were definitely not warm, however!
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • NomadPilgrim
    I found them at Target I think in the pharmacy area. Two kinds https://amzn.to/36aWycm and https://amzn.to/2sVUXZH but you can also use clumping kitty litter! Much cheaper. Works with a 5 gallon bucket with toilet seat on it too. (Luggable Loo.)
    Paulo Coelho
