400 UPGRADE TO A PORCELAIN TOILET AND KES SHOWER HEAD
JCALD
Member Posts: 132
(Title edited for search purposes. Moderator)
Just finished upgrading to a Dometic 301 porcelain toilet along with a new KES shower head and handheld bidet. The shower and bidet use the hot and cold mixing valve controlled by a selection valve just after the mixing valve. This enables them to both get warm water independently.
Is the toliet swap as simple as unbolting and replacing with new one?2019 T@B 400 Boondock Lite
Yes it is. Very easy.
What are the benefits of the porcelain?
The bowl is larger and more comfortable. Feels much more stable than the plastic water closet.
@JCALD did you install the low or high profile toilet?Happy Trails,
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
Did the low since it sets on a raised floor. Works perfectly.
@JCALD - how is the Dometic 300 on water use? How many days are you getting before needing to empty the black tank?
- 916 Introductions
- 72 Teardrop Groups & Links
