400 UPGRADE TO A PORCELAIN TOILET AND KES SHOWER HEAD
JCALD
JCALD Member Posts: 132
edited November 2019 in Modifications & Upgrades
(Title edited for search purposes.  Moderator)
Just finished upgrading to a Dometic 301 porcelain toilet along with a new KES shower head and handheld bidet.  The shower and bidet use the hot and cold mixing valve controlled by a selection valve just after the mixing valve.  This enables them to both get warm water independently.
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    Is the toliet swap as simple as unbolting and replacing with new one?
  • JCALD
    Yes it is.  Very easy.
  • Tundra57
    Tundra57 Member Posts: 640
    What are the benefits of the porcelain?
  • JCALD
    The bowl is larger and more comfortable.  Feels much more stable than the plastic water closet.
  • driftless
    driftless Member Posts: 135
    @JCALD did you install the low or high profile toilet?
    Happy Trails,
    Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
  • JCALD
    Did the low since it sets on a raised floor.  Works perfectly.
  • rhyno
    rhyno Member Posts: 393
    @JCALD - how is the Dometic 300 on water use? How many days are you getting before needing to empty the black tank?
