Toe Kick Plate
Have had an unsightly blemish under the shower door for several years:
Found a toe kick plate at Home Depot and cut it to fit.  A little pricey at $35 and made for 36" wide entry doors, but is a huge improvement over the soiled wallpaper.  This stuff is fairly thick and must be cut with a circular or Sabre saw.  Wanted to use two factory edges (left and top) so opted to add two screw holes on the left side that are not the same distance from the nearest screw holes to their right.  You ADD people saw that immediately!
