Tab 320 CS external shower enclosure
Dcj
Member Posts: 5
Greetings, we purchased a 2018 320CS and are looking for ways to provide an external shower enclosure. We've seen "hacks" where some have screwed PVC piping onto the trailer and installed some make shift PVC piping in a semi-circle around the shower with a shower curtain. The PVC piping attached permanently (or semi permanently) to the TAB isn't very appealing. Has anyone found a solution that they would be willing to share?
I have seen enclosed side tents in our color scheme for about $200 but don't know if they attach to the side of the trailer opposite the door. Has anyone tried?
We are newbies and appreciate any tips you can offer.
I used to use the pvc hack but have switched to one of those little pop-up tents designed for shower/changing. Search Amazon. They are around $30. Easy set up and take down. Take up almost no room when folded.2015 CS. Ford f150 v8. Southern california
Thanks. What do you do for flooring?
- 919 Introductions
- 74 Teardrop Groups & Links
