I have been watching a thread but it got very long and I thought my question might be missed. I currently have a Reese brake controller about 15 years old with my tab400/Toyota Tundra setup. I want to replace it. It seems that it is simply a timed unit with settable brake level.
I don't know if when I am stopped with brakes on are the tab brakes on too which might overheat them? If I'm stopped I turn the brake level down till I move again.
What are tabbers thoughts and recommendations for controllers where this doesn't happen. What is the trade-off between timed and proportional?
Are you pre-wired (a Tundra should be)? If yes then do you use only one TV? If yes then a hard wired unit will save you considerable money over an RF unit and save you some plug space in your cab...etc.
A proportional controller will cost more but is more suitable for a larger trailer. It will give you smoother braking, cause less brake wear, be more suitable for hills and "interesting" terrain. It would be my choice.
A timed controller is best suited for a small utility trailer, ATV or snowmobile trailer....not your 400.
2019 320 Boondock Edge - Sold Jan 2022
All other easily accessible spots would have been knee bashers.
Like available on F-150's, GMC/Chevy full-size and mid-size trucks, and several (larger) SUV models.
No idea why Ford did not include one in the 'new' Ranger - - big oversight.
All the vehicle factory installed controllers are Proportional Control.
2018 Tab 400
2019 Tundra CM
Wisconsin
2013 Tundra TRD 5.7L
Massachusetts
Hamburg, NY
San Diego, CA
www.airbossone.com
