Coax Spliter on Jensen JTV24DC
Anyone tried putting a splitter directly behind the TV so you can run either over the air HDTV antenna mounted in a window or campground cable via outside coax connection. Should work but curious. Happy Trails, All
San Diego, CA
www.airbossone.com
  • A coax switch would be needed, that would allow you to switch from one feed to another
    Tampa FL
  • Denny16
    Denny16 Posts: 5,430
    edited February 2020
    That is the best way, a splitter, while it works, would degrade the signal, reducing its strength.
    MuttonChops Posts: 2,051
    A 'splitter' takes one input source an outputs two or more identical (but slightly weaker) signals.  As @Tampakayaker stated you would need a switch which can switch between two or more input sources and output to one signal.
    For myself I don't fine it that much of a big a deal to manually change between the RV Park Cable or my OTA Antenna . . . 80% of the time OTA has better picture quality anyway.  RV Park cable TV is about as great as RV Park wi-fi.
    pthomas745 Posts: 4,648
  • AirBoss
    AirBoss Posts: 740
    Yes...meant to clarify. An "A/B" switch to toggle from park cable to OTA antenna. Cheers All!
    San Diego, CA
    www.airbossone.com
