Coax Spliter on Jensen JTV24DC
AirBoss
Member Posts: 740
Anyone tried putting a splitter directly behind the TV so you can run either over the air HDTV antenna mounted in a window or campground cable via outside coax connection. Should work but curious. Happy Trails, All
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
A coax switch would be needed, that would allow you to switch from one feed to another2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
That is the best way, a splitter, while it works, would degrade the signal, reducing its strength.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
A 'splitter' takes one input source an outputs two or more identical (but slightly weaker) signals. As @Tampakayaker stated you would need a switch which can switch between two or more input sources and output to one signal.
For myself I don't fine it that much of a big a deal to manually change between the RV Park Cable or my OTA Antenna . . . 80% of the time OTA has better picture quality anyway. RV Park cable TV is about as great as RV Park wi-fi.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
Towed by 2014 Touareg TDi -
Yes...meant to clarify. An "A/B" switch to toggle from park cable to OTA antenna. Cheers All!2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
- 916 Introductions
- 72 Teardrop Groups & Links
