Jensen Location - 400 w/ small fridge
Hello All,
Has anyone moved the Jensen unit ? In my 2019 - 400 it is located above the bed and is physically very awkward to adjust. You cannot use the remote from the dinette. However, I will try a round convex mirror mounted on a bracket that the remote signal can bounce off. The best solution would be to relocate it: but where, and can one obtain an extended wiring harness ? Thanks.
400 - 2019
St Catharines, ON
  • rh5555rh5555 Member Posts: 524
    Have you tried using the jControl app on your smartphone instead of the supplied remote?  It uses bluetooth and worked well for me from the dinette.
  • RCBRCB Member Posts: 224
    Rh555,
    Thanks, I’ll try it.
    400 - 2019
    St Catharines, ON
  • jameskuzmanjameskuzman Member Posts: 140
    @rh5555 - The jControl app has been hit or miss for us. Sometimes it connects right up, sometimes it doesn't.
    @RCB - You shouldn't need a mirror for as the signal from the remote is IR (infrared) and will just as easily bounce off of any hard surface that is situated in a way that can "see" the Jensen. I haven't tried working it from the dinette yet.
    I would suggest putting in a fresh set of name brand alkaline batteries in the remote though; the ones included with nearly all electronics remotes are cheap and half-depleted right out of the box.
    Jim Kuzman, Girard OH - 2019 T@B 400 - TV 2019 Volkswagen Atlas SE 4Motion w/ Factory Tow Package
