This morning I decided to test out the Jensen entertainment system and the television.  Followed the included directions.  Radio works.  DVD player does not work.  I tried 4 different standard DVDs (not blu-ray) that we routinely watch in the house.  Every one of them just say “loading” on the Jensen screen and I never get beyond that point.
Am I doing something wrong?  I’m back to wondering if there is any Quality Control in place at NuCamp.
                2 ·
The Jensen is mediocre, at best, but there are very few options in the RV entertainment system world. None of them seem to get stellar reviews.
I have noticed that your DVD needs to be fairly in pristine condition for the Jensen to work.
I have noticed on the walkthroughs of the 2021 mode
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
The Jensen has a larger than 2 din mounting hole but it's a simple affair to make a filler panel from plywood and mount it up. There are hundreds of options from there...
Here's a thread I did over on the T@G forum (same Jensen radio) on swapping it out:
https://teardrop-trailers.vanillacommunity.com/discussion/429/an-interesting-radio-upgrade-perhaps/p2
Upon first inspection, the wiring looks daunting, but it's pretty intuitive and not too difficult to do. The wires are all labeled and it's just a matter of matching the new harness to the trailer wiring, one wire at a time. There will be many wires on the new radio/head-unit that simply are not used. For example, most automotive radios come with a block of wiring that's for the "CAN bus". That's just tech-speak for "steering wheel controls". Unless you have installed a steering wheel in your trailer, you can simply ignore them.
For those with deeper pockets, a great upgrade choice is to install a boat radio. (check places like "West Marine" or "Overton's"). The primary advantage to marine radios is that they can, in some cases, be had with a wired (ALWAYS go with wired) remote. You can stick your radio in its stock location but add a remote panel in the galley or other handy spot. They are also mostly waterproof and hardy. Don't bother with radios that have wireless remotes unless you also want to accidentally turn on the TV or led lights, etc. Cheap wireless is rife with problems of that sort.
Then there are the computer based units. They generally use a touchscreen tablet as the user panel and have pretty much the same capabilities as a tablet. My entire music collection is in my trailer on a USB flash drive and is accessible from the menu. I can get from Chello Concertos to Aerosmith to Ricky Skaggs with the stab of a button. Once you've added USB, the sky really opens up.
Don't forget to remove the cheesy FM antenna and replace it with a better (longer) one if, like me, you listen to the radio....
WilliamA
2017 T@G XL
I notice the 2021 models are using a Jensen that has an HDMI port, but no DVD player, which is fine by me. I generally use miracast and my phone, anyway.
2024 T@g 5-wide Black Canyon
"Just Enough"
