2021 Slats retrofit?
targ
Member Posts: 86
Does anyone know if the new slide out bed slats that are on the 2021 320s will retrofit to a 2019 model? I don't think the basic seat/cushion dimensions have changed so it should work.
Is there a part number where we could order the new parts for a retrofit?
The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. |
-REBEC OF GINAZ
2019 T@B 320S BD Lite, Jeep TJUR, Jeep JT
I’m sure you could retrofit them but you’d be best to call a dealer for specifics and any part numbers, etc.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
You or any cabinet shop could make the new slat system up, not very hard, just need some if the furniture grade birch ply for the front support frame/legs. Slats can be made from oak. You will need to redo thes bunk tops, removing the solid ply and add some framing for the slats.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
I read on the FB T@B page that the new slat system can’t be used on previous models because the bench base was changed to accommodate the new slats.Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
- 919 Introductions
- 74 Teardrop Groups & Links
