1. Has anyone installed the Purple line RV movers on a 400 Yet? 2. Would someone with the Purple line system that has them please post pictures of how they are mounted to the T@B frame. Any comments of something you would do different if you did them again. Thanks for the info. Looks like it might be getting time to quit pushing and pulling to get it where I want it to be. Getting more senior!
0 ·
I think I did one of the first installations, but I have an Al-Ko I-Beam frame, so mine was bolted directly to the frame with some spacers we fabricated from steel as we didn't want to wait on shipment from the factory for the spacers. We also had to purchase longer bolts.
The single axle unit is designed to handle up to 5,000 lbs, so no issues there. The biggest issue is it IS a battery hog, so you need to have a charge line from your vehicle to have a good battery when you arrive, and a way to replenish your battery after use.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Tampa FL
Tampa FL
Tampa FL
This is my default wheel. Using the single wheel that came with my Tab doesn’t provide quite enough traction on the 12% grade of the worst section of my slick aggregate concrete driveway, though it does OK on the 6% grade of other sections. This double does slip a little, but not nearly as much.
Convenience wins out for your Quattro from Purple Line in my mind. I have to garage whichever trailer I end up purchasing...so a system like the Quattro is very attractive to me as putting the trailer away is going to a little tricky and tight in my garage.
Please do let us know your experience using the Quattro and thanks for sharing this info.
