Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Dump Valve Handle Replacement
ScottG
Administrator Posts: 5,655
Earlier this season, half of the plastic T-handle on my grey tank dump valve snapped off. It's still perfectly functional so I haven't bothered with it, but I'd like to replace it eventually--maybe with a metal option.
Does anyone know if the handle is a screw-off, screw-on replacement? If so, do you know the thread size, or a particular replacement that you know fits? Thanks!
I just checked a Valtera 1 1/2" blade valve I have laying around. The grey handle threads onto the metal shaft and can be replaced. The metal shaft attached to the plastic blade will spin, but not come off the blade.2016 Outback 320
Looks like I am in the same boat with a half-broken handle. From the looks of the design and the distance between it and the left front support jack, at some point they made contact. The result was part of the handle was broken off.
I think Scott is on the right track with a metal handle vs. plastic especially with it being close to the jack support. I am likely going to replace it with a metal handle. With that said, any recommendations for a supply source?Ballermaris
Tow Vehicle - 2018 Jeep Wrangler Unlimited
Trailer - 2016 T@B320S -
On this Amazon page, there are suggestions on "Customers Also Viewed" or "Customers Bought After Viewing" that might be your answer.
Towed by 2014 Touareg TDi -
TYBladesmith, thanks for the excellent link. I have ordered two handles since I have two dump valves on the T@B320S that I have. I consider that the other dump valve handle could be a liability even though not near anything but the front left side of the frame. If it is plastic it will break at some point.Ballermaris
When this happened to me, I repaired it with some JB Weld epoxy glue that I had on hand, and it's very strong, like new. That said, I'm keeping a metal spare, just in case.
https://www.amazon.com/dp/B01IBOK7FE
I've also used the JB Weld on other plastic parts, like the roof vent cover for the A/C air intake that got ripped off by a low hanging tree branch. That's like new too. Great stuff to have.
I went ahead with complete replacement of the handles since it was likely over time that age would factor in for the plastic and that it will become brittle and subject to breakage.Ballermaris
My black tank handle broke this week and it is marked as threaded. Brand is Bristol. Can get a replacement handle (plastic) on Amazon, but it appears that metal ones aftermarket also fit on the threaded shaft.
https://www.amazon.com/gp/product/B007HRMZC0/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab
- 916 Introductions
- 72 Teardrop Groups & Links
