Plumbing Resources
ScottG
Administrator Posts: 5,655
Diagrams, manuals, and other technical information about T@B Plumbing.
NOTE: Information specific to the Alde boiler is posted separately in its own category.
Plumbing Schematic (320S)
Description: Complete schematic of the T@B supply, DWV, heating, and propane plumbing. Based on a 2015 S model. Note that mixing valves and outdoor showers were not added as standard equipment until later model years.
EDIT (Oct. 2020): Note that the "check valves" indicated on lines entering and exiting the Alde are apparently NOT check valves but rather just connectors to facilitate the transition between different sizes of PEX tubing. An updated schematic is pending.
EDIT (Apr. 2021): The component labelled "glycol pressure relief drain" is mislabelled. This is actually the Alde flow assembly, which includes an automatic air bleeder and a non-return (check) valve. The Alde glycol loop is an open system that should not be under any pressure. Yes, an updated schematic is still pending... ;-)
Created by: ScottG
Posted by: ScottG
Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
Alde Mixing Valves
Description: nuCamp provided video link and technical bulletins with instructions for adjusting the domestic hot water mixing valve. Mixing valves were installed in T@Bs starting in 2016.
Added 4/29/2021 Speedfit Thermostatic Mixing Valves installed starting with 2021 models.
Created by: Airstream, nuCamp, Speedfit
Posted by: Hvtymwiltravel, Michigan_Mike, Ponzi, pthomas745
Original Mixing Valve Video here:
https://cloud.nucamprv.com/index.php/s/Z2pHmpFwQpfHoM9
Plumbing Compartment Components (320S)
Description: Annotated images of valves, drains, and other plumbing structures located in the Alde compartment. Based on a 2018 T@B 320 S.Created by: MuttonChops
Posted by: MuttonChopsDisclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.----------2015 T@B Max S (320)
Nautilus P3 Water Management System for the TaB 400 models
Description: Manufacturer user instructions for this system installed starting with the 2021 model year.
Created by: B and B Molders
Posted by: Cottonmouth
Added 12/6/21: Nautilus P3 Flow Schematic. Shows how various valve settings connect to plumbing components.
Created by: TomCanada
Posted by: Sharon Mathie
Added 12/6/21: Nautilus P3 Water Flow Path diagrams in addition to 3 D models and water flow part descriptions.
Created by: Muttonchops
Nautilus P 2.5 Water Management System for 2021 and 2022 TaB 320 Models
(Edit 12/7/22 - Refer to P3 instructions starting with the 2023 model year.)
Description: User instructions for this system installed starting with the 2021 model year.
Added 12/6/21: Nautilus P 2.5 diagrams detailing handle/valve settings and water flow pathways.
Updated: 7/7/2022
Created by: Brianb
Posted by Sharon MathieSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio -
Thetford Cassette Toilet
Description: Manual for the Thetford Cassette Toilets starting with the 2021 model year.
Created by: Thetford
LK550 Mixing Valve Operation and Servicing
Description: As the LK550 equipped campers age more folks will be reporting No Hot Water. It is very likely that Servicing the LK550 will resolve the issue for most owners.
- 916 Introductions
- 72 Teardrop Groups & Links
