Okay I have the T@B 320s and am towing with our 2020 Outback XT. All good so far right? Well I had a shop install the 7 pin and I purchased the Curt Echo wireless brake controller. Now were starting to get to my problem, Hot wire battery fuse is burning through. It is rated for 20 amps and the brake controller requires 30 amps. The 7 pin was installed using 12 gauge and from what I read I'll need 10 gauge to run a 30 amp fuse. Could I just use less breaking force through the controller i.e. set the power to 30 vs 50. It came set at 50 for the force. I don't want to have to rewire. Ugh, small worl problems I know.
0 ·
Talk with your 7-pin install shop on having them upgrade to 10-gauge wire and a 30-Amp fuse. It is possible that during hard braking, as Curt warns, and you are already seeing the 20A fuse will blow.
Now some factory installed 7-pin systems only have 20-Amp rating, Honda Ridgeline for example, so these vehicles would not be Curt Echo compatible without upgrading the wiring.
As for the Curt Echo. An interesting product . . . but . . . maybe it's not the ideal solution. A more standard wireless controller with an in TV control display might be better for you overall.
The Curt Echo also has one design feature / issue that is concerning. Curt's "How it Works" video says that when the TV hazard lights are on the trailer brakes will pulse on/off with the lights . . . so you cannot safety turn-on you hazard lights (flashers) while moving.
+++ I use them when backing up
+++ I use them on the highway to warn following vehicles of nearly stopped traffic
until there are a few 'also going slow' cars behind me.
Adventures: 52 Nights: 329 Towing Miles 41,900+
Is that right? What is it I'm missing?
Installation instructions state:
There is a thread on this forum discussing:
They all seem to use the TV Brake Lights On to activate then use their accelerometer to decide how hard (proportional) to apply the trailer brakes.
Curt Echo does have a software Hazard Override settings option. Setting Hazard Override On will allow the hazards to flash without causing braking. However, to have braking while the hazards are on
Driver Must Press the Manual Brake Button
. . . not a great solution since when hazards are on generally driver is already very busy . . . Also description of this software feature found on eTrailer, quoting Curt Support, is not 100% clear if Driver Manual Braking is needed all the time or just when hazards are active.
When purchasing my T@B had planned on doing a wired controller based on price differences. With this new knowledge on wireless would have been very disappointed with how they handle hazards. In the end purchased a TV with factory installed controller at a very reasonable option price, win win for me.
that said, it is illegal to drive with hazard lights on while moving, this is the rule in Calif., but a lot of folks do it. Flashing lights around here are for emergency vehicles only.
Last Trucker in a long line of nearly stopped highway speed zone traffic also use hazards to warn approaching vehicles, another hazard.
Just saying, there is a time and place for when hazards while moving makes sense.
Now have you confirmed the brakes work normal with the Hazards Off while override is selected ?
If bakes are normal would guess Echo has some type of timer to detect and ignore toggling brake lights - - - so watch how you pump the brakes, don't want to copy hazard on/off timing
If you are roasting your wiring and blowing a 30 amp fuse, you've got bigger problems. Here's a wire sizing chart:
http://fettingpower.com/home/helpful-references/wire-sizing-chart/
You can figure that a circuit should be sized at the capacity of the fuse, or the maximum amperage potential of the fuse. For a twenty amp fuse more than 10 feet long, you will need a 10 gauge wire. Not difficult to calculate.
Let's assume that ALL electrical connections are good. (This is not the case with my T@G. I ended up replacing several splices within the wiring due to failures.) Remember that in a 7 way circuit, there are more than brake amperage requirements. If you add up the individual potential amperage in ALL of the circuits, you'll find it's a surprisingly high number. All of that current potential feeds to the trailer on separate circuits, BUT! It all returns to the tow vehicle on ONE wire! The ground wire in the 7 way connector must be capable of handling the combined amperage of all 7 circuit potentials. Thankfully, this rarely happens and when it does, it's usually for no more than a few seconds at a time. You've got a 12 gauge (too small) wire going to the brakes, a 10 gauge charging wire, 16 gauge wire for various light circuits.....and one...single 14 gauge wire for the trailer ground. That is going to be one hot, busy wire. Do yourselves a favor:
First order of business in trailer wiring should be to make sure the ground wire coming from the trailer, through the 7 way receptacle, then back to the tv battery (not duct-taped to the exhaust tip for a ground) is 10 gauge, has proper butt connectors,( crimp-on connectors are fine so long as they are either heat-shrinked or are the heat-shrink type. These can be had at any auto parts store. They have a heat sealer within the connector so when you heat shrink them, the sealer melts and completely coats the inside of the crimp. Expect to pay $6 bucks or more for 5 or 6 connectors. If you are bound and determined that you don't need to run the trailer ground back to the tv battery, then at least use a nickel plated ring connector that won't rust, then seal it with some sort of coating to keep the water out.
99% of ALL light, brake, charging circuit problems on trailers can be eliminated by paying attention to the ground wire that goes from the plug to the chassis/battery on the vehicle side. If you go out and look at the ground wire on your vehicle-side trailer wiring, you'll see that it's no larger than the turn signal wire. I've seen factory and aftermarket wiring harness plugs that are as small as 16 gauge. NuCamp runs 10 gauge ground wire through the trailer connector to the plug. Do the same on the other side of it and you'll eliminate 90% of your problems. You might (will) also find that your tow vehicle can now charge your trailer battery in 1/3 of the time.
WilliamA
2017 T@G XL
