Trailer Tray A-Frame Cargo Carrier
Ballermaris
Member Posts: 32
I wanted to ask about what is called a Trailer Tray A-Frame Cargo Carrier. Has anyone had any experience with this going on a T@B320S? Or is it not worth considering due to the limited distance for the lid on top of the tank access area?
Ballermaris
Tow Vehicle - 2018 Jeep Wrangler Unlimited
Trailer - 2016 T@B320S
Is that the storage tray covered by a diamond plate lid between the front frame rails? Good place for storing your sewer hose, but it may take away space needed if you ever want to mount your spare on the front frame. There are other less expensive options for your sewer hose, too.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
The tank container has a top lid on it that is lockable. The Spare is mounted to the Power Jack at the front.Ballermaris
Trailer - 2016 T@B320S -
Teardropshop offers 2 different items. One includes a side tire mount. Check out the Teardropshop and search under Tab 320.
Thanks for the information on the storage box idea. For the amount of storage available within the box itself, I may decide to use the Tray Storage system, since it allows for a cargo box to be mounted with few holes to be drilled.Ballermaris
Is this the one you’re considering? https://www.campingworld.com/trailer-tray-a-frame-cargo-carrier-70918.html?gclid=Cj0KCQjwjoH0BRD6ARIsAEWO9DtMeS9G4wX4V9o86GPlMSO32tBOCYOXWOpFvmJG-E_Pl3uGXxhioMwaAunDEALw_wcB&gclsrc=aw.dsJohn, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Yes, that was the tray I was discussing. I was wondering if anyone had experience with it in use.Ballermaris
- 919 Introductions
- 74 Teardrop Groups & Links
