Step Light Plug?
T_BDancing
Hi and good morning. Saw this thing behind the step of my 2019 320 S and wonder what it is. I couldn't seem to find a post about this. It looks like a spring switch on the other side. Like a fridge's light. Light comes on when step is opened and turns off when step is closed. But I don't see any wiring around it at all. Do you find this thing on your T@B? Thank you.
Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L
2019 Tab 320 S Boondock Edge and get me out of NYC!!!
Interesting. I have not seen that. I didn't think the 320's ever had a step light until the 2021 models. Did you buy your T@b new?
Thanks @jkjenn, it's a 2019 model and I bought it off the floor of a dealer. I could not find any info from Project2000 (manufacturer) website either. weird!Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L
2019 Tab 320 S Boondock Edge and get me out of NYC!!!0 -
Our 2019 320S does not have the part you are referencing @T_BDancing. I'm fairly sure our T@B was early in the year's production run, as we purchased in August of 2018.
Hope this helps...
2019 320 Boondock Edge - Sold Jan 20220 -
T_BDancing said:
. . . 2019 model and I bought it off the floor of a dealer. I could not find any info from Project2000 (manufacturer) website either. weird!WAG #1: Project2000 sells so many electric steps that even manual operation steps are built with a switch included to save on inventory stocking.
WAG #2: When NuCamp added the nicer step to Boondock models and knowing that adding a step light was planned for future, they just ordered the 'with switch' style
WAG #3: Due to WAG #1, NuCamp decided to add a step light on the newest production model T@B
@T_BDancing; Which model number step is NuCamp installing?
@CrabTab, just looked at the label I actually have a 2018 from September. Not sure that's supposed to be a 2018 or 2019.
@MuttonChops, thank you for the info. Any idea which light I shall look for? Since it's only a switch does that mean the light will have to come with some sort of wiring to 12V or built in battery pack? Thanks again.
Not that I must have a step light. Like some people pointed out on a different discussion that a step light is not necessary when we have a porch light. I am not a very handy person when it comes to electrical stuff but if it's a plug & play then why not since the switch is already there.Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L
Our date of manufacture was in July 2018. Your T@B may be a newer version of the 2019 year than ours. As I understand it, they make upgrades/changes mid way through a model year run.
2019 320 Boondock Edge - Sold Jan 20221 -
Simple solution, buy a small flashlight. Then you have Step & More Light when needed.T_BDancing said:Not that I must have a step light.. . . not a very handy person when it comes to electrical stuff . . .'18 320 S, pitched axle, 3020HE; PNW based
@MuttonChops, I know, I have tons of flashlight laying around. Thought this would be something fancy to have.
Checked all over. Looks like the factory version will have to come from Italy or UK. I may have to leave it for the later days.
Let see what else I can do during this social distancing...Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L
2019 Tab 320 S Boondock Edge and get me out of NYC!!!1 -
A discreet step light might be nicer in the evening than the super bright porch light that lights up the neighborhood. You’d still have the option to turn on the porch light if needed.2016 cs-s max0
I mounted a motion activated solar porch light to the side of my door, under the handle. It does a good job of lighting the step and I hardly use the original porch light anymore.
2 -
I don’t mind the porch light on mine at all because of the amber color instead of the white. Just wish it could be remotely controlled! Am I asking too much?
There might be another explanation. It's possible that some RV's have a safety switch circuit to prevent (or warn against) driving off with the steps deployed. That seems more likely to me than a step light that would be on all the time the steps are out. No reason you couldn't use it for that though....
WilliamA2021 Jeep Cherokee Trailhawk
2017 T@G XL
Can generally be found around west-central Wisconsin.2 -
The 400's had a lighted step from at least the 2019 MY, the step light is on any time the step is not stowed. The pictured switch looks similar2019 T@B 400 Boondock Lite1
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
