Aluminum Tub Rubber Trim
Has anyone ever changed/replaced the rubber trim on their aluminum tub?  Specifically, I am referring to the curved side sections of the tub, which align with the curve of the front exterior wall of the T@B?  I need to replace mine and can use standard automotive trim, which is readily available, but I am curious if anyone has found rubber trim similar to that used by nüCamp.  Thanks!
