3 way frig door rack hack
Dalehelman
Member Posts: 2,414
First I want give credit for this idea to a fellow T@Ber I had the pleasure to meet in Riverside CA. His name is Deac he has a new Sofitel and travels alone. He tells me he is 78 I would have guessed no more than 68. If you meet him along the way tell him Dale said hi. It is made from a poly ice cube bin from Walmart. We have wanted to put small items in the door rack to make them more accessible, but they constantly fell out Deac's idea works perfectly.
- Hash T@B Fun
3
I was able to view them with no problems
That's genius! Thanks for the pics, too!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Cool, gonna have to do that.0
Very smart!James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback0 -
Clever idea! (Is there ANYbody out there who hasn't had things fall out of those door racks??)1
I am going to do that asap, I wouldn't use it because everything kept falling out!! think you can silicon it into place, so it doesn't slip around, or does it need it?
Easier to clean if not attached?gbell said:I am going to do that asap, I wouldn't use it because everything kept falling out!! think you can silicon it into place, so it doesn't slip around, or does it need it?James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback2 -
Will a full-sized wine bottle even fit?0
I suppose it depends on your definition of "full-sized"...
Makes my daily allotment almost rational!
Box wine is commonly 3 liters or a double magnum size.
Rehoboam in terms of Champagne Bottles is only 4.5 litres or 6 bottles. Methuselah is the same size as an Imperial (6 litres) but the name is usually used for sparkling wines in a Burgundy-shaped bottle.Apr 16, 2012 from Wine Folly (respectful apologies for the hijack)((But! I didn't start it!))
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner1 -
That particular bottle (an 18L "melchior") would be almost 9" in diameter. Most definitely too large to fit in the door of the 3-way Norcold without modification.
There. With apologies to all concerned, we are now back on topic! :-)
If cut just right I think it should wedge into place.gbell said:I am going to do that asap, I wouldn't use it because everything kept falling out!! think you can silicon it into place, so it doesn't slip around, or does it need it?
Or buy two ice bins so you can mess up on the first one.
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0 -
Want to thank Dale for the inspiration - Walmart was out of the ice cube buckets so used a tupperware type bread box - Cut two of the sides out - It's a little wider and you can see thru it ... Still need to polish the edges...
6 -
Nice option PXL!
Eric aka: Lone Wolf0 -
The scrap...
PXL, put the lid back on, and use it on the driver's side underneath the bench for additional storage to keep things contained, and from sliding around.
Eric aka: Lone Wolf1 -
Thought about cutting the cap and blocking the end but the insert's wide enough that not much can slide out the ends.0
You got to love options.
- Hash T@B Fun
Until you did that, don't know why it hadn't dawned on me - Stuff falling out was sure annoying ... Thanks1
Deac and I just crossed paths - At a dump station of all places :-)3
I hope to do this soon. Do y'all think that a command strip caddy would stick inside the fridge door. I have really learned a lot about my new to us Tab.
Ted and Jan Pasadena, Texas 2015 Tab S towed by 2007 Toyota Tundra0 -
YesTedandJan said:I hope to do this soon. Do y'all think that a command strip caddy would stick inside the fridge door. I have really learned a lot about my new to us Tab.- Hash T@B Fun
B+ is fine by me. Sad to say, by the second glass, almost any wine I drink is "Wonderful!" And we know a 6-pack would fit the fridge! We'll look for it.John, Judi, Guinness & OD in PDX
I just happened to notice... I haven't seen any posts by pxl/nomad for a while. Is he living off the grid? I'm not prying or anything. Just concerned cause he's been a great guy and a good source of info as well...ericnliz said:Nice option PXL!
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI1 -
Dalehelman said:First I want give credit for this idea to a fellow T@Ber I had the pleasure to meet in Riverside CA. His name is Deac he has a new Sofitel and travels alone. He tells me he is 78 I would have guessed no more than 68. If you meet him along the way tell him Dale said hi. It is made from a poly ice cube bin from Walmart. We have wanted to put small items in the door rack to make them more accessible, but they constantly fell out Deac's idea works perfectly.
- Hash T@B Fun
