I have a question about the rear underside position where if the spare tire was not mounted to the front jack or the frame, what are the two bolts that are presently there tied to? Is there steel or some other metal backing plate in that area behind them?
The reason I ask is if those two bolts, which would normally hold the spare tire of my 2016 T@320S if it was mounted there, what is the weight capacity (load limit) of the bolts?
It would stand to reason that at some point the T@B320 would likely hit a low spot and the tire and rime would impact briefly until it cleared, so the rear of the trailer would have to endure some form of stress without ripping the underside off.
I am trying to find something to mount that would fit there such as a Class 2 bolt-on receiver that would only carry a bicycle rack at is 30 pounds, and the total weight that those bolts would support would be 135 pounds max.
I gave the Up-N-Front mount a try, but that will not be doable since I have a wireless brake controller mounted in the area where it would mount.
I am exploring other options, but my Ebike weighs 75 pounds so I need something heavy-duty to carry the added weight. I am considering a front-mounted carrier on my Jeep Wrangler too. A tire mounted carrier would not work since the carrier protrudes into the turn radius of the trailer and towing is not recommended with those.
The last option I would do is remove the front wheel of the bike and stow it in the cabin of the trailer.
To give you the perspective of the Ebike here is a link to the unit I have ordered and one that is on its way.
https://www.radpowerbikes.com/products/radwagon-electric-cargo-bikeIt does have some extra goodies I ordered with it coming so the bike might not even fit through the door of the 320S.
As a Pick-Up Truck owner I can store my (full size) eBike in the truck bed {purchased longer bed size just for that}. Purchased the Pick-Up because Jeep options on my short list lacked easy eBike and other bulky cargo storage options. . . . not that any of that helps you
I still miss my pink Specialized bike (half the weight of your eBike) that was ruined when my bike rack on the rear of my Silver Shadow Teardrop broke due to the boomerang effect.
Thanks for all the help.
Tow Vehicle - 2018 Jeep Wrangler Unlimited
Trailer - 2016 T@B320S
Odessa, Fl.
The install facility will have to do a modification to the underside of the bumper, but it will bolt right up.
That will take the unsprung weight off the trailer.
