sewer hose storage
Camak, do you think my left hand mild shears would cut that curve?2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
get 320 next week, going to take a look at doing that...2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
@trimtab, this thread may help you out:
https://tab-rv.vanillacommunity.com/discussion/comment/108692?fbclid=IwAR0XkGbBianPKfhrcNUTSWhyJNBRuc4ERGdzzLqnuVPEkkX31xRgWHBCAH8#Comment_108692
The only comment I would add to the original instructions is that it is best to use wider/thicker zip-ties. I replaced the ones in the photos with 18" zip-ties that I purchased at Wal*Mart (5-pack), which fit that description. I just cut off the excess after I tightened them down to the Boondock platform. Even if they were to break (highly unlikely), the sewer tube won't go anywhere since it will stay within the area it is located at the base of the aluminum tub.2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Trimtab, the shears may work, my shears are in NY so I used a jig saw instead
Thanks all! I will be doing that mod.2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
I just added a Super Slider (The Valterra’s we’re sold out) for storing my sewage hose. I’m pretty proud of myself since I am a 62 yr old, single lady. I put it on the opposite side because my RF Brakes were already mounted on the side where the I would have preferredKathy - Lansing, MI
2017 T@B 320 SC-S, 2016 Suburu Outback -
Nice job, @MichiganSunshine........you just earned a gold star!2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
- 919 Introductions
- 74 Teardrop Groups & Links
