Adding Additional Plugin from Inverter on 2019 T@B 400 BDL
My wife would like an inverter plugin on the countertop of our T@B 400.  Has anyone tackled this project.
I would appreciate any advice on the installation of an additional plugin.  TIA
    How big is your inverter, and where is it located.  The wiring is in a chase under the galley counter, and has an access by removing the corner panel on the bunk end of the counter, where the existing factory outlet is located.  The inverter circuit is isolated from the other outlets in the TaB 400.  You could just move this outlet and extend the wires, or add another one in parallel with it.
