Adding shocks to a Dutchmen T@b?
mdomb529
mdomb529 Member Posts: 39
edited June 2020 in Modifications & Upgrades
Is this a job I could do at home or does it require a lift and/or other specialized skills/tools?
Has anyone managed to find an aftermarket alternative (that is hopefully cheaper and more readily available in the US) than the Al-Ko octagon green shocks?
Thanks!
Matt
Appleton, Wisconsin
2006 Dutchmen T@B ("Fuego")
TV: 2007 Nissan Pathfinder
  • Mouseketab
    Mouseketab Member Posts: 1,262
    It is very easy to install the shocks. I installed mine myself. Here are the ones you need
    https://www.trailertek.com/brand/al-ko/al-ko-shock-absorber-kit-green
    They are not cheap, but that is the only ones that will work. You need the kit that includes those metal things, not a set with just the bolts.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • rfuss928
    rfuss928 Member Posts: 1,196
    edited June 2020
    Alko shock kit as installed on our 2009 T@B.
    This picture shows how the brackets supplied with the kit connect the shock to the swing arm of the torsion axle.
    Image result for alko torsion axle shock kit
    There is a discussion here about adding shocks.
    https://tab-rv.vanillacommunity.com/discussion/10375/shock-absorbers
  • mdomb529
    Perfect. Just ordered them. Shipping was a doozy, but at least there was an 11% off coupon code, we don't get charged VAT, and the pound is still relatively weak, historically speaking.
    @Mouseketab - Are you aware of any attempts by anyone to set up a DM T@b buying group for consolidating orders shipped from overseas?
    Matt
    Appleton, Wisconsin
  • Mouseketab
    No, I really don't. I've ordered a few things here and there from across the pond, just by googling for what I needed. I got my shocks, jockey wheel, stabilizer nut, etc.
    Carol
    MOUSE-KE-T@B
    Harvest, AL
  • mdomb529
    edited June 2020
    Thanks, @rfuss928. I had previously found the post you linked, but it's a lot more meaningful to me now that I've looked at the product on the website linked by @Mouseketab. I love this forum!
    @rfuss928 and @Mouseketab, will I need to lift my T@b and/or remove the wheel in order to install the shocks? If so, I'll have to start thinking about which friends I want to hit up for help :-)
    Matt
    Appleton, Wisconsin
  • Mouseketab
    No you don't. I believe I just lowered the tongue really low and crawled under.
    Carol
    MOUSE-KE-T@B
    Harvest, AL
  • mdomb529
    It might be worthwhile for those of us who are still running the DM T@bs to create an email list so we can give others a heads up when we're about to place an order in case anybody wants to join, especially if there's flat shipping. I suppose this type of arrangement might require some inconvenience for the person placing the order. But, for example, I'd love to place an order for multiple sealed bearing kits and give others the ability to purchase them at a more reasonable cost than they're currently available through Nucamp or by ordering one set from overseas. I just spent $290 to have my local dealer install bearings, and I'm certain that if I had the bearings myself and took it to my local mechanic, it probably would have cost me half that.
    Matt
    Appleton, Wisconsin
  • Mouseketab
    Actually, nuCamp stocks the bearings and brakes for the Al-Ko frames. Just call a T@B dealer (Princess Craft in Texas does great for parts), tell them you need a set of bearings or brakes for the Dutchmen T@Bs, then they will have them drop shipped to you from nuCamp. I replace my bearings myself. Jack up the trailer, put it on jackstands and take the hubs to a machine shop to have the old bearings pressed out and the new ones pressed in for about $20, then put it all back together. I keep a set of bearings and brakes on hand at all times just in case because it can take time to get a set, and that is not good on the road.
    Carol
    MOUSE-KE-T@B
    Harvest, AL
  • mdomb529
    I ended up installing the Al-Ko shocks on my T@b.  Here's my semi-in-depth discussion:  https://tab-rv.vanillacommunity.com/discussion/11122/dm-t-b-i-installed-al-ko-shocks/p1?new=1
    Matt
    Appleton, Wisconsin
  • dyoakum
    dyoakum Member Posts: 2
    I am having trouble finding these shocks available. They don't want to ship to the USA. Any tips on how to order them?
    2003 Dutchman Yellow T@B
    Tucson, AZ
