Need my 5 gallon portable water tank replaced??
CRETBO
Member Posts: 25
My water pump hooks to it in my 2005 T@B .... (it leaks) having a hard time finding a replacement? Needs a garden hose connection on top to screw the hose for the water pump into it? Can't find on-line anywhere??
2005 T@B Dutchman
2019 Tacoma
2019 Tacoma
A picture may help.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Here is two photos ... has to be a garden style hose hook up on the one side
**** Can't get them to upload
2005 T@B Dutchman
2019 Tacoma -
Here is what the Dutchmen water jugs look like. They are really hard to find these days.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
This may be something you might consider. It actually costs less than only the 5-gallon jug was when it could be found. (If I remember correctly, they were more than $120). Then you could mount it under your sink, and plumb it up. You might have to add a fresh water fill through the side of the camper. https://www.amazon.com/Class-Customs-T-0500-BPK-WFCO-Plumbing-Concession/dp/B07KMGNVQK/ref=pd_sbs_263_5/130-2666904-1066949?_encoding=UTF8&pd_rd_i=B07KMGNVQK&pd_rd_r=c4bee828-d131-4128-a66f-8dfd718c0518&pd_rd_w=v3LHQ&pd_rd_wg=XB5AS&pf_rd_p=d9804894-61b7-40b3-ba58-197116cffd9d&pf_rd_r=NS21CT837ESNVWQEK156&psc=1&refRID=NS21CT837ESNVWQEK156
Carol
MOUSE-KE-T@B
Harvest, AL -
Thanks ... thats the one... Does Nucamp sell them still? Sad is I have the water pump already all set up. Might have to do a conversion to another container and get an adaptor at a hardware store... mine leaks aweful... thanks for the pic as that's the one in your pic.
Bob2005 T@B Dutchman
2019 Tacoma -
Yes, that's another option. Just get a container that will fit in the space, and adapt the hose connection to the container.
No nuCamp does not carry those water containers any more.Carol
MOUSE-KE-T@B
Harvest, AL -
Too bad it’s got to be food grade, or a person could modify a 5 gal gas can. But then it’s opaque too.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
I am thinking a large vegetable oil container may work. Find a restaurant supplier maybe?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
