We purchased our T@B secondhand, and the original owners never used the sink/stove. I looked up on the SeeLevel owner's brochure and didn't find the simple answer I need. My unit does not have a wet bath/shower. Only a sink with no hot water. The panel has a toggle switch with pump on one end and a green light on the other. The buttons are BATT, FRESH, GREY and BLACK.
So, here are my dumb beginner's questions:
1. The water seems to come through the faucet whether the pump toggle is on (toward the green light) or off. Which position should it be in most of the time? (at rest)
2. The Fresh water display never goes over 75%, and I'm not sure it ever gets to zero (Just disinfecting the tank right now). And the Grey water says Opn. Do I need to take it in to get those fixed? Is it important to?
0 ·
a] When on City Water the SeeLevel Panel Pump should be off.
City water source will provide water pressure. Do use a 50 PSI regulator on the city water hose so your trailer pipes do not get damaged.
b] When not connected to City Water, turn-on pump (LED on) when you wish to use water.
It is good practice to turn pump off when water is not needed.
Also, is it normal for the sink to drain very, very slowly?
Thank you for the rest of the information as well. Is it difficult to do what the owner's manual says to do on the error message?
Thank you, Lissa
Unless the original owner changed things the sink will have a standard house style ' P-Trap '. It is easy to remove and clean out the trap on the chance it is clogged.
How Difficult a DIY task is depends on your present skill level and how comfortable you are with - - that's not what I expected situations - - once you start taking things apart. Sometimes a second person helps, even if their skill level is no better than yours, two sets of eyes, two brains, and four hands.
“Sorry I'm not real sure how to respond to an individual person on this format.“ Just put a “@“ directly in front of the member to whom you are responding. If they selected to be notified, they will receive a notification that they have been mentioned.
