Entry Assist
TabRookie
Member Posts: 29
Does anybody know if the swing out entry assist bar from the Cirrus camper is compatible with the Tab 400? I'm sure it will cover part of the galley window when in the stowed position but will the mounting brackets line up with the existing grab bar on the Tab? I've already asked Nucamp and they basically said I'm on my own with this one. They couldn't say if it was compatible or not and suggested contacting you fine folks for input.
Thanks
Thanks
I haven’t seen that anyone has installed one, but have often wondered why nuCamp didn’t make it an option on Boondock models with their greater height.
You may want to review this thread. While it deals with the 320 and adding an inside handle, it has a lot of info shared from customers in contact with nuCamp on how these rigs are actually constructed, and might be helpful in figuring out how to safely mod your Tab for better accessibility. https://tab-rv.vanillacommunity.com/discussion/8012/grab-handle-for-2018-320s/p12019 320s BD Lite, white with blue (“Haven”)
Pacific NW0 -
@TabRookie
Are looking at this type of assist handle?
Stromberg Carlson AM-200 Lend-A-Hand Assist Rail - White
by Amazon.com
Learn more: https://smile.amazon.com/dp/B0002F68FO/ref=cm_sw_em_r_mt_awdb_zoR8EbJEKYK0M
- Hash T@B Fun
@Dalehelman yes thats essentially what I am looking at. There is one that comes on the Cirrus and I was hoping it would easily fit onto the Tab without having to drill new holes. It's unlikely they will line up like that but you never know.0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
