Battleborn LiFePO4 100Ah; straight switch with original Interstate on a 2019 320s?
dno
dno Member Posts: 42
Hi, newbie just setting up for my first excursion with my 2019 Sofitel 320s. My 320 has factory solar with the Victron controller. I'm planning to swap the Interstate my 320 came with for a Battleborn 100Ah, for the available juice on a daily basis, charging flexibility, and to lighten the tongue weight (I moved my spare up there). So my question is, would this be a straight swap, or is there something I need to reset in the controller, and is the original converter ok or do I need a new one? I know there is a lot in here about this subject but after an hour of searching I've yet to find the answer to this specific question. Thanks!
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    Technically they do take a different charging profile, and that is easy to change in the Victron charge controller for the solar part. No way to change the WFCO settings, so that would be a swap out. Many seem to get by ok with the solar taking up the slack where the stock WFCO falls short, but to do the swap 💯 correctly you would charge out the converter too.
  • dno
    @N7SHG_Ham, thanks! Can you point me towards an appropriate converter, or possibly steer me towards a post by someone who has done this?
  • blueangel
    blueangel Member Posts: 14
    edited June 2020
    I will be picking up a new TAB 320s with two battleborns this week.  I plan to let the solar do the job of topping the batteries off.  I really don’t think a special charger is needed as is confirmed on the Battleborn site.  https://battlebornbatteries.com/charging-battleborn-lifepo4-batteries/
  • blueangel
    edited June 2020
    In the past I have charged banks of deep cell batteries by targeting a specific charging voltage with a power supply like the one in the link below to charge from either a generator or ac outlet directly to the batteries.  I will be using Anderson Power Pole connectors to make it easy to hook up the power supply to the batteries.  https://powerwerx.com/variable-power-supply-digital-meters-30amp
  • Marceline
    Marceline Member Posts: 1,773
    If you mostly boondock and you have factory solar there really isn't much point in switching out the converter since you will mostly be charging the batteries from the solar on the roof.
  • dno
    Thanks all, most informative!
  • N7SHG_Ham
    @dno check out Progressive Dynamics converters. I believe they have lithium replacement charger sections for the stock WFCO. WFCO may also have them now too?
  • dsfdogs
    dsfdogs Member Posts: 641
    @N7SHG_Ham in my '18, the WFCO is a 35amp converter. I recently checked both Progressive and WFCO and their lithium replacements are all more than 35 amp. So the question is, how can I know if it's safe and the T@B wiring will accommodate a higher amp converter? nuCamp could/would not say.
    Debbie in Oregon
    Sold 2023 Tab 400
    Sold 2018 T@B 320S
  • N7SHG_Ham
    Off the top of my head and this may be wrong, I think you would only need to change the wire size between converter and battery? The LiFePo4 battery can take a much higher charge, the rest of the stuff in the camper will use the same power.
    AM Solar in Springfield may be a good resource for doing a proper install.
  • Denny16
    Denny16 Member Posts: 5,430
    That is what I would do, upgrade the cable from the charger to the battery to the correct size for the cable length.  On DC circuits, the amperage, and cable length together determine the correct wire gauge.  You can find a chart on line.
  • 1968Healey
    1968Healey Member Posts: 64
    WFCO has come out with their own Lithium lineup of chargers, some are direct swaps, some are built into the power centers from the start.
    The Progressive Dynamics converter might actually damage LFP batteries. In the research that I’ve been doing it looks like it never exits absorbtion (14.6V) and basically attempts to over charge the batteries too often. This means you might need to disconnect power when storing your T@B.  That isn’t something I want to deal with.
    The Victron charges have ‘storage mode’ where they drop the charge voltage way down is they don’t detect a discharge load over 24 hours.  Seems like the best solution to me, but they’re quite expensive.  The 30amp Phoenix charger is ~500 bucks, the 50amp is $675 or more.  The lower powered 25amp Phoenix charger is more reasonable around $300, but then you get a charge rate even lower than the stock WFCO.  That might not be much of a problem if you have time to charge once you finally plug in.
    2020 T@B 400
    2019 Toyota Tacoma TRD Off-Road
    Seattle, WA
