Shower door trim and grey tank seal
Saravtower
Member Posts: 31
Ok fridge is staying closed! Two more issues...inside the cap of the grey tank dump site the seal that keeps the cap attached has broken.
Also, the long black trim that runs down the inside length of the shower door slid out, broke to pieces.
Are these parts that I can replace?
T@B 320s, 2017
T@B 320s, 2017
An easy fix for the gray tank cap is to replace it with this:
The trim that you refer to is a magnet to keep the shower door closed. Contact your local TaB dealer to order that part for you.
Thanks!!
- 920 Introductions
- 74 Teardrop Groups & Links
