New owner of a Boondock, with some recent discussion on changing a flat figured I better do a dry run. SO located the nut to release the spare and noted a clever "nut adaptor" was included with the new owner items. However a long arm with excellent grip strength would be required to release the spare. I then spent some time going through my tool box and came up with a 7/8" socket + 10" drive extension + 3/8" hex adapter in conjunction w/ my drill, makes the process easy to drop the spare. Now I'll need to duplicate this set for my trailer tool kit or better idea, ask the forum! Anybody know of a device like a super long spark plug wrench? I don't want to move the spare yet as I prefer to use the front tray for other stuff...  Also I found the supplied adapter is a tight fit and was difficult to unjam on the nut so I went with a standard socket and since I carry a cross bar lug wrench it's not needed.
managed by VE Smart Network
0 ·
When I put it back up, I find I have to raise it until the tire contacts the frame, then use my foot while sitting on the ground to push it toward the rear so that it sits level when raised. It usually takes me a couple tries.
Though your comment on storing the stabilizer handle reminds me of the other minor rants on the 2021 why did NuCamp remove the door into that compartment - I hate having to raise the bench to get in there. The door was convenient to access chocks/leveler/handle/hose/cable. Also why leave a 2-3 inch toe grabber beside the bench? My wife and I both have tripped on this. Otherwise we love the changes.
